It looks like you're new here. Sign in or register to get started.
Alswagg said: Starboard front corner of the motor. Not too bad. I am 225+- I can fit in there no problem
howardrams said: The cool fuel module is the separator, basically, in place of the old spin-on type water separator.
I believe you have to remove the cool fuel module, or at least loosen it, to get to the impeller housing.
On a side node, what props are you running?
Should I install another after market?????
