Coffee maker works and microwave out
Got the microwave out by taking out the screws out from under the cabinet pushing it back.Took the screws out off the black starbrite then pulled it out forward. Pretty tight with plywood screwed to the bottom of the micro. Reach around the corner and unplugged it to find the coffee maker not plugged in. Grab the cord for the coffee maker to find butt connectors. Did Rinker do this?? Plugged it in and it works.
    I believe the coffee maker plugged into the back of the main electrical panel
    Looks like Rinker had to extend the cord to get it to plug in to the back of the panel
    Yes the plug  on the panel is marked coffee maker and micro. Plugged in just to verify it worked then put back in the right spot.
    Mine is not like that. Mine coffee makers plugs into the panel but the cord reaches with no problem.
    Mine was also extended
    2002 Rinker FV 342
