Water Heater Elimination.
My electric water heater hasn't worked in years. I disconnected power to it back then until I had time to look into it. This has not been much of a concern because we still get plenty of hot water after running the engine. The old heater started leaking rusty water last year. Has anyone done, or heard of looping the hoses in order to eliminate the water heater, but still get hot water from the engine? Would this work?
    Look, a fellow Pittsburgh boater!!! Where do you boat at?
    Unfortunately no. You still need the tank to heat the water.
  • LaReaLaRea Member, Moderator Posts: 8,069 mod
    No, I don't think it works that way.  My understanding is that the system circulates heated seawater or coolant from the engine into a heat exchanger that is inside the water heater.  You can't pump cold fresh water into the engine and get hot fresh water out.
    See the picture below.  The electric heating element is in the center, and the heat exchanger runs along the outside.
    I think you are stuck spending $300 for a water heater.
    http://stevedmarineconsulting.com/water-heater-primer/
    He boats where the Penguins are boating now. LOL
    The Pens can't win it every year.
  • micktumicktu Member Posts: 7
    No, but what a run.
    Thanks for the reply.
    Thank you all.
    No, but they did against the Caps.
    @micktu, just install a new heater. Its nice to have when you need it.
