12 volt accessory outlet fuse
WillhoundWillhound Member Posts: 4,221 ✭✭✭✭✭
The 12 volt accessory plug in the v berth wasn't working so I pulled it out to check the connections and discovered this goofy fuse set up. Never seen a fuse like that with a little terminal on the ends. Will pick up a conventional style fuse holder and replace it. Just a FYI for anyone not getting power to an accessory outlet.
