Gas Cap
trich11trich11 Member Posts: 108 ✭✭✭
Does anyone have a source for the o ring for a gas cap on a 2004/312 or 2002/342??
  • mvnmvn Member, Moderator Posts: 754 mod
    Have a look on this website.  Find the one that looks like yours and it should show the replacement o-ring.
    http://www.iboats.com/Replacement-Vent-Cap-O-Ring-Retainer-Perko/dm/cart_id.303337974--session_id.122222833--view_id.482275
    No marinas in the area have any?
    Mark
    2019 MTX20 Extreme
  • trich11trich11 Member Posts: 108 ✭✭✭
    They are all saying they have to order the cap to get the o ring. This search is for one of my buddies so that is the info he is relaying.
    Nonsense.  The seals are most likely Buna N (nitrile) and are very common (see attached).  There might be an industrial seal place near you that can easily provide a replacement.  Or you could try an industrial supply place that deals with hydraulic stuff.
    Mark
    2019 MTX20 Extreme
    Find a Motion Industries or ATI branch, if you have some calipers to measure the ID and the o-ring dia you can get one cheap.  Most are Nitrile or Buna-N, if you can get Viton it is a better seal material.
    I found them at my local ace hardware.  I replace them annually so I buy several at a time.
    I went to a NAPA Store they matched it up
  • jean-mariejean-marie Member Posts: 8 ✭✭
    Hello,
    I had the same problem.  The rubber rings don't last long.  I found replacements at Home Hardware.  They don't last long though.  Change every year.  Disintegrated seals were the reason water was getting into my port tank.
    Nitrile o-rings degrade from UV and gasoline over time. Add in the friction from removing/installing the gas cap and they wear out. Use some silicone plumbers grease on it to help. Or upgrade to Viton if you can find them.
    edited March 2014
    Well, I have the perko part number for the o-ring only.  It is 054000099B.  Available through multiple websites.  For purchasing your own material o-ring, the size is 1-3/4 x 1-1/2 x 1/8 and the 'dash number' is -224.  Butyl-N is a buck or two, Viton is $2-4 from what I can find.  I just bought a bag of 10 from a guy in Vegas on eBay for $8.70 shipped to my house.  Figure I will keep a few spares in the toolbox for anyone else at the marina.  For that price, I figure go right for the Viton.  It was a PIA to find the size of the dang o-ring online.  No place that sold the Perko replacement listed the sizing, including the Perko folks.  Thanks to forums such as this, I tracked down a group that had a discussion going, and someone had measured and photographed the fill, so they figured it out from there.  I love this forum (and other forums) for the ability to help and be helped by so many people.
    Gary and Diane
    290 FV Nauti Bonnie
    Viton is the way to go, about 2-3x the cost of nitrile is about right.
