Starboard Lenco trim tab will not go down.
AnyfiveAnyfive Member Posts: 33 ✭✭
Need help!
The starboard trim tab is not retracting.  It was working at put-in but at first time out only the port side was working.  The hydraulic oil level is fine.
I suspect the up or down relay.
2005  250 Fiesta Vee
    I thought Lenco's had electric actuators, not hydraulic.
    Mark
    2019 MTX20 Extreme
  • raybo3raybo3 Administrator Posts: 5,618 admin
    Mine are electric. I think the hydraulic fluid your talking about is for the trim cylinders...
    Exactly.
    2019 MTX20 Extreme
    You probably have a siezed or cracked actuator.  You could put power to it direct and by-pass the switch, then you'll know forsure.  Look for cracks or separation on the housing, you might even see water/oil weeping from it when it should be dry.  Smart move is to replace both if one is bad.
    Go to Lenco's website. They have a troubleshooting guide that will help you find out exactly what the problem is. Been there done that. Good news is boat does not have to come out of the water to fix anything on the system.
    Bella Sabrina II  370EC
  • AnyfiveAnyfive Member Posts: 33 ✭✭
    Excuse the confusion of the hydraulics (used for the out-drive trim).  The problem with the electric trim tab was the relay.  Have one on order.
    Thanks for all the help.
    Anyfive
    Where is that trim tab relay located? When recently try to trace a trim tab issue I found a black box approximately the size of a cig pack very much buried down in the helm underneath the steering mechanism and wiring harness. If that's it I dread the day it'll need service.
    The black box is for the 'smart tabs' that retract when the boat is off and have the lights to show you where they are up/down.  Otherwise all you are doing for up/down is reversing the current to the actuator..no relay.
