Canvas Zipper Broke after only 13 months.
MarkBMarkB Member Posts: 4,006 ✭✭✭✭✭
edited June 2013 in Rinker Support Q&A
My zipper broke.  I've only had the boat 13 months. There's an end piece that keeps the zip together when it is zipped up.
Where can I get this piece? What's the warranty on the canvas?  Thanks
See this picture.
 It should have an end piece like the one I'm pointing two.
    call a local canvas guy. MIght be able to crimp in a new piece, otherwise it's replace the zipper time.
    Call the canvas company.  I bet they will take care of it.  You should get at least 10 years if taking care of the top.
    Those just 'pinch' on. 1 min fix at a canvas place.
  • MarkBMarkB Member Posts: 4,006 ✭✭✭✭✭
    I called the canvas company, Ameritex Fabric System. Unfortunately no sympathy from them. They do not cover the zipper and so after only 1 year of use (and I've actually only taken this piece off 2 times EVER) - I get the "It needs to be replace. I'm sure a local canvas company can fix it".
    ... that is exactly what I wanted to hear.
    Can't Rinker step and provide some support here?  This is pure BS.
  • NY320NY320 Member Posts: 19 ✭✭
    A canvas place will charge you 5 bucks, it takes 1 minute . Just bring it to your local place. I'm sure if you asked Ameritex to fix it if you shipped it to them they would.
    My issue is I can't take it off and leave it exposed for weeks if I am to send it to Ameritex. I am in Canada.
    I will try and find a local canvas company to fix it.
    Thanks NY320.
    Here's a link to an upholstery supply place in Ontario (Midland).  In your case Mark, you're better off just finding a local top shop to fix your zipper.
    http://www.jtstopshop.com/
    Mark
    2019 MTX20 Extreme
    edited June 2013
    Frustrating I know. But it can be fixed for a couple of bucks, the stop/start of the zipper is put on by hand since the zipper is a long part cut to size. Save yourself the agony and get a local canvas guy to fix it.
