Power for Amp
Willhound
Member Posts: 4,242 ✭✭✭✭✭
Installing my new stereo and speakers today. I would pick the hottest day of the year!
Also just realized that I forgot to get the y cables that @Cableguy Greg mentions in this thread. https://rinkerboats.vanillaforums.com/discussion/8481/wiring-6-speakers-to-4-channel-amp-how-to-handle-fade-control#latest
Anyway, lots to do before I get to that.
The amp manual calls for a direct battery hook up with 8 gauge wire and then the remote on feed from the head unit turns it off and on. In a perfect world I'd like to take the feed from the acc position at the ignition switch, but I doubt the wire feeding it is anywhere near 8 guage thereby defeating the purpose. Correct?
Ok to take it from the back of the battery switch? I don't like the idea of taking it right off the battery.
I used one like this, available at West Marine.
https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A
https://www.ezacdc.com/
Do you have Amazon prime? There's wire options there...but I'm not sure if prime works for Canada
Prime is available in Canada but still a 4 day delivery as it comes out of the US.
Like with everything else on boats: Imagine explaining to your insurance adjuster that your boat burned down the marina because you didn't want to wait a few days for the right kind of wire.
https://www.amazon.ca/Electrical-Battery-8-Gauge-25-Feet-ANCOR/dp/B01BES1U7S
They did my last boat a red 30 Ft Donzi and just did my friends brand new Yamaha AR.
Guys name is Chris, and you can tell him Tim with the Donzi and Jeff with the Yamaha suggested he call you.
He he also does mobile stuff FYI if you get stuck.
Ordered from Binnacle last night. Arriving Monday which works for me. All marine grade wire and fusing. In the meantime I can run my speaker wire and the lighter gauge feeds for the speaker LED's and the head unit. Have another job too. When I pulled the fridge to track some of the wiring and pull the old CD changer out this is what I found. Bringing the rubber gloves, bleach and anti mold spray to the boat tomorrow!
