110V outlet broken
jandav
Member Posts: 41 ✭✭
The power outlet that sits beside the cooler in the back is broken so I need to replace it.
Where can I order such outlet? I can send it to an adress in US so no need for intercontinental post...
Suggestions..?
Thanks in advance
Jan Davidsson
Sweden
Suggestions..?
Thanks in advance
Jan Davidsson
Sweden
Can you send a picture? Normally they use standard receptacles (power outlets) used for homes ... and they are connected to a GFI protected circuit.
Same sort in in the lavatory.
/Jan
He's in Sweden.
Jandav, yes as Greg says you need a 15 amp US duplex outlet/receptacle. But one of your receptacles will be a GFI ... I'm not sure if it is that one. Does it have a LED light on it, with a reset button? Basically, these are used in homes here in North America, they are standard receptacles ... but you'll probably need to buy it on Amazon, as Greg says ... I'm fairly confident you can get it delivered to Sweden.
@MarkB What is GFI ? the outlet has not any green LED or reset button.
I will be in US in a week so I can order at any e-shop that deliver within US..
The suggestion to bye a outlet with USB preferable...
Was home depot.com a joke or a good suggestion?
TIA
/Jan D
