Determining Fuel Usage
We're bringing a 40 ft Express cruiser home from NJ to Newport. Has anyone done this trip and how can we determine fuel usage per hour at cruise speed of 20 knots?
Best Answers
LaRea
Member, Moderator Posts: 8,030 mod
Congratulations! Welcome to the forum!
What's the propulsion package? If she has gas 496 with Bravo 3 outdrives, you can expect around 0.75 mpg at 30 mph, assuming good weather and decent bottom paint. You can probably slow down to 23 mph (20 kts) if you want, but you'll burn a lot more fuel. The boat's much happier at 27-30.
With v-drives, 23 mph might be right, but it won't get 0.75 mpg. -
Willhound
Member Posts: 4,237 ✭✭✭✭✭
More like a third of that. 151 miles ÷ .75 mpg = 201 gallons."Knot Quite Shore" - 2000 FV270 (Sold)
Well, I'll say for 150 miles, plan on using somewhere between 200 - 240 gallons of fuel. I've done a 160 mile trip to VA beach for 4-5 years in a row and I burned anywhere from 210-250 gallons, depending on conditions. You should be able to make it on one tank, but if conditions are rough I'd keep an eye on fuel level just in case.
@LaRea is very close to the burn level of .7 - .75mpg. Sorry @alswagg , but 0.9 is only pristine days going with tide. (I've seen 1mpg for brief periods)
What year is your new 400? We love our 400! This will be our 7th summer with it! You'll find that 30-32mph is the perfect cruise speed. Welcome to the forum!
Yes, mine is bottom painted, but not overloaded. But, I do ride often with another boat that is the same, but no bottom paint, except it has B3 drives and he burns very close to the same as me, maybe just a tad better. Although I do seem to burn a little better (more around .08mpg) with the new HM props now.
Doesn't sound too bad. What was the distance?
I do keep her on a lift, so she stays clean. Boat was already bottom painted when I bought it, so I thought it'd be best to maintain the bottom paint. Some people in my marina just let it all wear off, but that can't be very good for resell. I would think the next owner would have to clean it all off, put new barrier coat and then paint if they were leaving in water again.
to e.
i Cruise at 24-25mph
