Water Heater Problems
onislandtime
Member Posts: 309 ✭✭✭
I have changed the element and still no hot water. I have hot water obviously after running engine. What should I check to trouble shoot?
https://rinkerboats.vanillaforums.com/discussion/8736/atwood-water-heater
I may be looking for parts myself. Although finding the reset thanks to @reneechris14 got me working I found last visit to the boat that it kicked out again, so now I suspect the thermostat.
There's a whole 120V electrical system that must work. I'd start there.
Mine was popped (again) and after reset I had hot water within 20 minutes. Not sure why it is popping, there really isn't an adjustment on the thermostat, I think either they work or they don't. It may be from me leaving the tank turned on all day on an extremely hot day and then running the boat which may have pushed the temp beyond the threshold of the reset.
Anyway, where the extra time came in was from trying to get the bottom bolt back into the right spot on the metal cover. Tiny little screw in a very tight spot that you can't see, at least not on my 270. My back is still sore today from all the twisting around.
Anyone see the thread on TheHullTruth: whenever the guy unplugs from the dock he can't run the AC or use his 120V outlets, and can't figure out why, but he doesn't own a generator or inverter. That was a painful one...
The guy that bought my 280 called me a few months after the sale with the same question.
