Horizon 600 windlass problem
04FV270riverrat
Member Posts: 268 ✭✭✭
so my windlass on my 270 will let the anchor down, but won’t pull it up. It pulls really slow for about 10-20 seconds, then it blows the 50amp breaker back by the battery switch. I tested amp while pulling and it draws about 34 amps before the breaker pops. All connections are tight (switch/breaker isolator/breaker at battery switch panel). Once it pops the breaker a couple times, it won’t move in the up function at all. I’m hoping the motor inside the windlass can be rebuilt or replaced. Anyone ever have this issue?
https://www.p2marine.com/simpson-lawrence-horizon-freefall-parts
Also in the Q&A section of the listing.
The gear moves up and down on the shaft very little but when it moves down, it causes friction, but only in reverse. You can feel it while spinning the armature by hand.
He's going to see if he can get the gear to stay up with another washer/thrust washer and see if that fixes the problem. We are assuming that the friction caused is why it spins slower in reverse than forward and then when a load is added it creates so much friction that it's drawing too much amperage and blowing the breaker.
I'll update tomorrow hopefully with the results.
@J3ff you don't happen to have yours apart right now do you?
Sorry, it's wackamole. The curse of the 12+ year old boat.
then there are 3 bolts that hold the motor to the housing
