Adjusting compensation on compass
Spyderweb
Member Posts: 951 ✭✭✭
This compass is on my 2008 330. How do you adjust compensation? The direction pamphlet talks about the adjusting screws directly below luber line and just to the right of line. I don't see anything there or anywhere's else. The Phillips screws showing are the mounting screws.
Note the wiring behind the dash can throw it way off. Did on my 342. Do NOT use your cell phone compass to true it. They can be way off.
Using your cell phone compass typically uses the cell towers for north and can be way off. You can turn that setting off to use GPS instead.
I used my handheld compass to verify my new one. It was spot on out of the box.
