Shower sump on starboard side by AC condenser
Anyone has a water line diagram for a 2008 Rinker 260 EC?
Found a shower sump on the starboard side by the AC condenser( very hard to get to) bilge pump wasn’t working and water was poring in the aft .
Changed the pump with a new one , but the water it’s not going out , somehow it’s dumping inside the boat (aft location)probably broken pipe
Anyone experienced this problem, or is aware of the sump by the AC condenser ??
Im trying to figure out where the bilge hose should dump since nothing comes out of the boat but instead dumps in to the boat.
 Thanks
  • rleonerleone Member Posts: 6 ✭
    There are 4 outlets on the starboard side of the boat. The bottom left should be the AC, the bottom right should be the helm drain. It os going to be one of the top two. I am not sure which one it is. One will be the shower sump and the other will be the mid bilge pump. You are missing the lit on the shower sump box. The hoses can be accessed thru the bathroom by removing the toilet paper holder or if you have an access under the sink.
