Replacing antenna cable 2008 260EC
Antenna cable broken and separated from screw in connector on Tv antenna mounted on radar arch. Do I have to replace the whole antenna cable and if so any tips on how difficult or not this job will be?
    If its just pulled out at the fitting and standard coax cable you can get a twist on connector for a few bucks.
  • aero3113aero3113 Member Posts: 9,660 ✭✭✭✭✭
    Should be an easy fix if it’s just the connector. You can YouTube it and instructions should come with the connector, weather it be a twist on or crimp on.
