Bank 3 60 amp fuses keeps popping. While on generator, and shore power 2001 310
patiomanpatioman Member Posts: 1
In the past few days the 60 amp breaker in the battery box keeps intermittently popping. Any suggestions where to start ???? There's no continuous activity spiking it.
    That's a big amperage breaker to keep popping.  Unless the breaker is bad, something is pulling too much current / shorting out.  You might try to isolate it by shutting off everything you can and then one by one turn on until it pops.
    Is that 60 amp breaker part of a load circuit or part of the charging circuit?
    Mark
    2019 MTX20 Extreme
