hot water heater problems
Spyderweb
Member Posts: 946 ✭✭✭
Admiral's been complaining water is not as hot as last boat. Upon checking, found heater is plumbed to engine, and since we don't go that far, it never gets really hot. And we're getting nothing from the water heater on shore power. Found Attwood manual online and read parts on checking continuity on thermostat, ECO and element as well as checking for AC.
Tore into the heater yesterday and all parts checked out. Except no AC. But when I hooked all the wires back up I had AC. And a short time later I had very hot water. I fixed it. Figured it must have been a corroded wire that got cleaned up when I took it off.
Get up this morning, turn on heater breaker, and an hour later nothing but cold water. Tear into it again, planning to remove one wire at a time (after confirming continuity is correct still), looking for culprit. 1st wire I take off is right above reset button on ECO. I push it in as I did last night, and again it's not obviously resetting, but I did feel almost a slight click. Maybe it did reset. Check for power again (after plugging in shore power), and voila, I've got power again. And 30 minutes later a check shows I have hot water.
So now it appears I'm losing power due to the reset button tripping. What would be the reason for that, and what part(s) needs replacing?
@Willhound, we had the same idea as you to make the heater work in the meantime. Likely to spend several days on the boat over the 4th, (before part arrives) so planned on running water heater no more than 30 minutes at a time.
Thanks for the help everyone.
