2006 360EC won't plane
I have a 2006 360 w/ twin 8.1OSi 374HP volvo's and Ocean X penta duo prop drive. the bottom is clean and paint is fresh.  Any idea as to what the problem might be
  • aero3113aero3113 Member Posts: 9,722 ✭✭✭✭✭
    When is the last time you changed your fuel filters? How old is your fuel?
    What are your rpms at wot......twin 496s that thing otta go like a bat on fire! Trim and tab settings? Have the drive ram shims been moved. Even that shouldn't stop those 496s.
  • CoastalGroupCoastalGroup Member Posts: 13 ✭✭
    I had a similar issue last year and posted the issue on this forum.  I received Lots of interesting inputs that you may find useful...you may be able to review on "my discussions" page.  I eventually discovered that I had a trim tab issue. I had a leak in the hydraulic line feeding my trim tabs, thus preventing them from going up/down and thereby preventing me from getting on plane.  I was really surprised that the non working trim tabs had that much impact on my boat, but once repaired I was able to get on plane without issue.
    There could be a fault code on the engines causing them to go into guardian mode, or whatever Volvo calls it.
    Volvo guard lol
    Velvet guard
