Another Lenco question
My LED position indicator switch lights up so I know it's getting power. However, neither tab will operate. I have the old style controller. Any thoughts on trouble shooting will be deeply appreciated.
Best Answers
skennelly
Member Posts: 2,196 ✭✭✭✭
Controller is bad or actuators are bad. You can test the actuators by applying 12v to them independently. Not sure how to test the controller.
I've heard Lenco are helpful if you call them2002 - 270FV Mag 350 B3 -
LaRea
Member, Moderator Posts: 8,040 mod
Did they both fail at the same time? The most common fail is off-season freeze damage from failure of an internal water seal, so two at once is rare and would suggest a controller fail. -
FDNY49
Member Posts: 116 ✭✭
Thank u 4 the input Problem solved, one actuator had a short which for some unknown reason effected the good actuator.
