Thru-holes for mounting water pump to engine bracket
LaRea
Member, Moderator Posts: 8,040 mod
For my raw-water pumps, I have a question about replacing tapped holes with thru-drilled holes and a nut/bolt.
I'm talking here about a Merc 350, 496 or other engine with the raw-water pump mounted on the front of the engine. There are two horizontal bolts that hold the pump to the mounting bracket. These bolts mate to threaded holes in the pump body. Removing and installing them can be a real pain. The bolt heads are on the back side of the pump, so they are hard to reach. On one bolt, there's not enough room for a socket wrench, and barely enough room to even get the bolt into the hole. Because everything is so hard to reach, it's easy to get these bolts cross-threaded, which causes even bigger headaches.
I want to thru-drill these two holes, and use bolts with lock-nuts. I think it would be much easier. I could use a socket wrench on the front side, where there's easy access, and a box wrench on the back side. And if a nut ever gets cross-threaded, just replace the nut and bolt.
Is there any reason not to do this?
It would be awesome to have all the bolts accessible from the front so I didn't have to do that.
I don't see the advantage of doing this just to the mounting bracket....maybe I'm not understanding @LaRea reason.
I remove the pump from the bracket. It's three bolts. The vertical bolt is easy to reach. The two horizontal bolts are a PITA requiring triple-jointed monkey-long arms.
@LaRea, you may just want to start removing the idler pulley and take bracket off with the pump. Then the bolts are pretty easy to take on/off and don't have to worry about cross threading. Much simpler (IMO) than the route you are taking. & I actually have a ton of room to do it the way you are speaking of, but it'd still be more difficult.
Oh, and I don't see any reason you couldn't drill thru and use nuts on the back.
