Flow Rate of 342FV A/C Pump
Here's a question I seek from the true 342 "pros" out there! My 2005 342FV is on a lake lift, to prevent constant waves/chop while we're relaxing on the water. So far, so good. However, just raising the boat 10" was sufficient to expose the A/C intake port. Unwanted air now inside the lines, but I can bleed the system and remove the nasty air. But, I don't want to constantly go through that drill. I'm seriously considering just inserting a small water pump into the system that bypasses the hull intake. (I really need A/C cooling during these hot summer months in Alabama!) I 'd like to match the GPH flow rate of the factory pump, but I can't find any specs that tell me what the "standard GHP flow" is.
Does this info exist anywhere?
Has anyone tried this procedure, or am I just wasting time with an unwise project? Your thoughts always welcome!
Thanks!
Thanks!
