How do I remove the waste holding tank from my 2003 342 Feista vee rinker.
stanmikostanmiko Member Posts: 3 ✭
The waste holding tank on my 2003, 342 Fiesta Vee, Rinker has the input spout broken off at the tank.  How do I get this tank out of the boat?  I believe the rear birth bench seat back has to come out but I can't seem to get it out even after loosing all the visable brackets and screws.  Is there some adapter to fix this or must I replace the complete tank?
    Possibly thru the storage bin behind the mirrored door in the rear berth. Al might have a better solution. It looks like a bugger to do having crawled around mine in that area far too many times.  lol  Might be a big job.
  • stanmikostanmiko Member Posts: 3 ✭
    That area is too small remove the tank.  You are able to see it from that access point.  The back rest from the lower birth most likely needs to be removed but I can't figure it out.  Is there anyway to contact the manufacture for advice?
    edited July 2013
    Alswagg is the guy to ask on here. There might be a sawzall in your future. :bz
    wow that sounds messy. getting it out is one thing. putting a new one back in might be another if a sawzall is used.... my 320 the starboard engine would need to come out. $200 tank costs $1000... brilliant!
    Yeah. I'm thinking this is big $$$.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,957 mod
    Definitely post some pictures for others that may have to do this in the future as well.  Good luck and keep us updated. ;)
    Documenting this process would be great for those of us with 342's!
  • trich11trich11 Member Posts: 108 ✭✭✭
    I hope I never have to do it on my 342!!!!
    I had a 342 for a couple years. I have taken that rear berth totally apart and I know you can access the tank that way. Just take your time piece by piece. Start with the trim and lights and work your way down. I suggest replacing all the sewer lines while you are at it. Once that is open it is real easy. (Fuel tank senders too really)
    Bella Sabrina II  370EC
    @Explore7427:  Did you have to take the headliner down too?
    I have mechanic working on it.  I will keep all interested posted!
    I did not have to take down the headliner to get to the tank but I did not remove the tank. I just replaced all the fittings and lines.It has been a while so I can't picture it exactly but it really wasn't that bad to take the stuff apart.
