Removing my TV
MarcdohcMarcdohc Member Posts: 58 ✭✭
Hello, I plan on removing the heavy old style TV from my 05 300 FV. I glanced at it the other day and I couldn't see what was holding it in place. Does anyone have some tips for me? Thanks
    I know mine (342) was screwed in from underneath the sliding table it was on.  Screws went into the corners where the rubber feet would normally be.
    My '04 270 had an L bracket with a couple of SS screws on each side. I bought an LCD w/built in DVD player and actually patched the sound into the on-board stereo. It's a life saver if it's too rainy or blazing hot during mid-day.
    If you haven't been shopping yet, make sure it'll wedge into the new spot, has a 12v power jack and a headphone output jack if you intend to patch it into your sound system.
    Good luck, Mike
  • MarcdohcMarcdohc Member Posts: 58 ✭✭
    Thanks for the response guys! Yup, it was the 2 screws going up into the front where the rubber feet would have been. Thanks again.
