Drive Slip
Willhound
Member Posts: 4,241 ✭✭✭✭✭
I've recently had an issue crop up that has me a bit perplexed. About the last 4 or 5 runs, when coming up on plane I could sense (and hear) that I had slip in the drive line. But only the first time I come on plane for the day.
I should start by saying that I have now put about 160 hours on the boat and the issue has only been the last 20 of those. From the start I've always run with full fuel and water tanks and usually 2, sometimes 3 on board. I don't believe it to be prop slip or I would have had the issue from the start, I would think. The first time it occurred it felt like I had weeds wrapped around the prop, and when I stopped, briefly reversed, and then moved forward again I think I did see a mass of weeds float up. But the weird thing is, it only happens at the beginning of a run when leaving the harbour. Once on plane and running a bit I can stop, hammer the throttle and jump on plane with no slip whatsoever. My first thought was prop hub slipping caused by the first weed issue. But wouldn't that happen all the time? I also wondered about the cone clutch, maybe only happening until things warm up? But I would think that would get worse as things heat up?
Drive oil is good, no milk in tank and no drop in level. Anything else I need to consider?
dirty bottom won’t create slip but drag which will translate to hard and long plane time
or having a wrong prop
is she getting to the rpm needed to plane with this happens ?
Just that first initial getting on plane for the day. After that, I can go half a mile, come down off plane, hit the throttle and get right back on plane with no issues. And every time after that .
