changing coolant
rasbury
Member Posts: 9,027 ✭✭✭✭✭
I have had my boat for about four years and have never changed the coolant. Most of it was lost in another incident some time back so it had a lot of fresh coolant. Being that the engine is sitting in my garage would seem like a good time to change it. I will do a little searching but I'm sure someone van give me the best way to do it and to fill it without over heating the motor
..350 mpi 2006 motor. I'm almost ready to put back in the boat..will bring the boat home to pull the out drive and hook the steering back up. Then, get scheduled with the marina!
Drain, flush with water, fill. You'll need a air compressor. The airlift sucks air out creating a vacuum, and then you throw a valve and fresh coolant is pulled in... It May take several cycles to fully charge coolant, but when its full there is zero air in system..
Another thing its good for is pressure testing coolant system. Simply draw a vacuum, say to 10 inches of vacuum, and walk away. Let it sit for however long, say an hour, and when you return to it there should still be 10 inches of vacuum on system... If there isn't, your system isnt sealed and an open system will overheat. I think (iirc) one pound of pressure raises boiling point of water 3 degrees... So, has to be sealed. The 13# cap allows a 39 degrees over 212degrees at seas level. The problem with open system that isnt designed to be open is the coolant is pushed out and there will be no cooling at all.... The airlift will find if youre not sealed quicker and far easier, with a certainty, and is worth the trip to shop to rent... I like it so much I bought one.
If it were me I'd find a compressor and an airlift and be certain its done right...
Good coolant goes about its business one of two ways... It either puts a skin on parts that protects them, or it makes them super slick. You can't mix these. If you go from one to another you've got to flush thoroughly. Even better if you use restore and restore+ following directions to a T, but hard to do to marine engines.
