trim limit senders
rasbury
Member Posts: 8,964 ✭✭✭✭✭
One of my last things on my list is to install the trim sendor/senders or what ever they are called. I bought news ones when I revamped the transom assembly. So, we have the new wires laying across the motor. On top of the motor you have two connectors for one unit and for the other, two connectors for the other up in another harness along the transom. Question is, which connections are for which sensor? Also how do I figure out which set of wires for the senders on the inside of the boat go to which sensor? Can I hook up a meter and get a resistance reading or something?
Starboard is the gauge
Coming though the transom port to the trim pump and starboard the engine harness. Just my guess.
Also, looking around....see this one wire not hooked up to anything, don't see anywhere to plug it in...also, notice on my plug wires a plug in with nothing pluged into it, assume it is for something else. I really did not take any thing loose on the motor it self when I pulled it.....you know, other than the out drive fluid line and minor things like that...
test light?
ground it and poke one of the wires
hit the switch either up or down and see if you get power to the pump
check other wire
three wires
clock
couner clock and ground
now check pump ground wire with bolt meter
basicalt put neg on post and pos on battery pos
Yours must be different as mine looks like above - no plug that I recall. Unless these go up to a plug and socket up at the motor top like you have to connect to the run from the helm.
