Tachometer
DaveG
Member Posts: 23 ✭✭
My boat is a 2004 RINKER 342. Both of my tachometers are not working correctly, both show wrong RPM at different times. If you tap on tach they will start to work correct but soon after they will act up. Any one have any luck getting them repaired or should I just replace them? Second question is hour meter info stored in tach or come from engine ECM?
Thanks
Thanks
Both - tach stores but in ECM also and a more accurate record of hours per RPM range.
