Adding a Third Battery
rinkedout
Member Posts: 5 ✭✭
I will be adding a third battery to my 290ec along with a battery connected inverter to provide power while at anchor. The 3rd battery will run parallel with the "house" battery. Anyone advise on the proper way to connect the batter charger in this scenario? Do I need to account for anything with alternator charging while boat is running?
Thanks, Rinked Out (Buffalo, NY)
https://www.iotaengineering.com/pplib/balancedcharging.pdf
You're right that it will work either way. But you might see a slight gain in performance by wiring them correctly.
The first time I heard of this was 2015 when @Michael T brought it up. Lots of web sites mention it, but I didn't really understand it until I found that article from Iota Engineering.
In my system below, the house bank is the 2 batteries on the right. The charger is out of the picture on the far right. It appears to me that the 2 charger leads both attach directly to the center battery. To even the amps up a bit, I think I can just move the red cable from the center battery over to the red lug on the right battery, as indicated by the arrow.
Am I interpreting that correctly?
Paul
Ingenious!
