How did I do this, again
rasbury
Member Posts: 8,992 ✭✭✭✭✭
So, weekend before last was our trial run after reinstall of motor and transom. It is the ramp at one of our Marina's I used and do not like. The floating dock gets real short when the water starts dropping....so when I put the boat on the trailer I would put the trailer in the water the minimal amount and kept pulling the boat up and backing the trailer until finally getting loaded if you can Invision...the dock is so short if I backed it in enough to load properly I could only get off the front- no way I had the hull out of the water but I burned up the impeller...and the second time I've done this at this ramp. The answer is obvious, quit doing it but I don't see how I ran it dry!
I do think you aren't getting the prime. You need to make sure the boat is all the way in the water before starting each time. I had a pump that was doing this to me (with my boat on a lift, it is the same type of thing). I found that my wear plates on the pump were really the issue. It just didn't prime as well. New plates and all was fine.
