New blower question...thanks
cls10105
Member Posts: 352 ✭✭
One of the blower plugs do not work. Both of the motors work off the one plug any ideas on how to fix the other connection. Thanks for your help
cruising on 6. tw0s
Post edited by cls10105 on
The helm switch will power both plugs. The cabin switch will only power the 3-wire switch.
Here's a wiring schematic.
FWIW: I had to run a new/clean ground wire from the fire extinguisher to that light. Also had to replace the factory wire connection at the fire extinguisher (big resistance problem and major heat at the connection with the blowers on).
