Jabsco Electric Toilet
trich11
Member Posts: 108 ✭✭✭
Last night my Jabsco 37245 toilet stopped pumping waste out of the bowl. It will run to pick up water and the tank is not full. I checked the rocker switch and swapped leads without any change. The pickup lead works on both sides of the switch. Ideas? No luck on Jabsco's site for troubleshooting.
Did you check whether the breaker popped?
I had to replace the toilet motor on my FV 310. Found the best price on AMAZON.COM
http://www.amazon.com/Jabsco-37072-0092-Designer-Assembly-12-Volt/dp/B000O8AZOO/ref=pd_sim_sbs_sg_4
Good Luck
John & Kathy
2002 FV 310 "pair*a*dox"
Yes I understand it is 12v,so is mine. You can use the 12v power for tthe vacuflush system to power the electric toilet. So how is yours powered?
