I would like to upgrade my sound system. Has anyone addned a subwoofer. If so where did you place it in the boat. I can’t seem to find a good solid flat location.
The 342 has it by the captians feet. My 280 had a box constructed by the PO with 2 subs in it located in the storage under the cockpit seat that was on the port side. The back seat would be a good spot, in the fiberglass under the seat facing forward.
I have a 310 and wanting to do the same. The ones I’ve seen with the factory sub, have it mounted on the square panel at the bottom panel, to the right of the helm seat. Not sure about the best way to run wiring.
Just my $0.02
