New Air Unit in 2003 342 Rinker FV
Currently the old unit is 16000 BTU  115/60 with passport controls.  Needs a replacement - would the Marine air - 16K Btu air and heat pump 110-1120V/60 Hz be compatable?
    Certainly should be.  You want to double check the dimension on both and the newer units tend to be more compatible/adaptable to where the output air goes.  Power wise, yes it should be fine.
