Refrigerator
cls10105cls10105 Member Posts: 389 ✭✭
Something else, hoping nothing. Went to the boat the refrigerator was working and got to it today and it is not. Any help would be greatly appreciated thank you
cruising on 6. tw0s
    Of course first check to see if it works on shore power or dc, May work on one or the other. Then pull it out and check the two fuses in the board. Stern side of the back of the unit. Two automotive like fuses in there, mine wasn’t working and found a fuse had blown (from me stupidly trying to connect a house battery backwards)
  • cls10105cls10105 Member Posts: 389 ✭✭
    @Liberty44140, does it just slide out or are they screws that needs to be removed first
    cruising on 6. tw0s
    First - I am talking about the galley fridge, not the cockpit fridge. Cockpit fridge may be the same but I've not changed any fuses in the cockpit so I cant speak to that.
    On the galley fridge, you remove the screws in the trip all the way around it and it slides right out. If you have a wood floor put down padding so you dont scratch it and while you are there I'd vacuum the fan and compressor and make sure the AC and DC power is plugged in well.
    Both frigs are screwed in. Front flange to cabinet. Just slides right out from there.
    Worth seeing if it works on AC or DC. The AC side can come unplugged.
    Help, took the refrigerator out tried plugging in a fan abd it wouldn't work. Plugged the refrigerator into another outlet and it worked. The breaker dont look to be out...help please
    cruising on 6. tw0s
    Crisis adverted. Alcohol was the problem. Sorry guys but thanks
    cruising on 6. tw0s
     :D In the fridge or the technician?  Happens to the best (and worst) of us. Glad it's working for you now.
    @Black_Diamond lol...very true
    cruising on 6. tw0s
    Future reference, they are 9 screws to take out and the fridge slides right out.
    cruising on 6. tw0s
