Shower sump issue
So not a Rinker but still a normal Rule pump and you guys are pretty good at solving these issues. So I replaced my shower sump with a new Rule pump. Installed the new one and nothing comes out. Disconnect the output hose and water shoots out like a garden hose. Blow through the output hose with my mouth and no problem. With the hose connected I turn the pump on and the level drops a little then stops dropping. I turn the pump off and it backfills back into the dump back to the original level. Stumped here.
make sure you have an open vent on the shower box too!
I fix it by pulling the pump out, then stuffing it back into the housing.
How high is it lifting before it is discharged. Basically, you don't have a strong pump, so imagine the line fills up, and it tries to push it up 3 or 4 ft, and it just can't, so the water just sits there in the line with the pump spinning. When you stop the pump, it loses pressure and all that water goes back into the sump.
I can think of 3 issues:
- the pump is not generating sufficient pressure
- there is a restriction in the line and the pump cannot overcome that restriction
- the height the pump has to elevate the water too is too high.
Too much uphill really doesn't make sense, I put it up there, because it is a possibility, but those pumps should be able to pump to the top of your radar arch. I would say restriction or the pump is not generating pressure (it's broken).
