Greasing Gimbal Bearing
Willhound
Member Posts: 4,238 ✭✭✭✭✭
When changing out my anodes the other day I noticed the grease fitting on the transom housing for the gimbal bearing looked dry. I have my drives serviced every fall by my tech at same time as winterization and he normally greases it then. I thought maybe he just missed it, so went ahead and gave it a good half a dozen or 10 pumps. Did my drive coupler at the same time. Remembered later that I had the gimbal bearing changed as part of a drive overhaul last year and I know a lot of the new ones are sealed, non-greasable. I wasn't sure if that's what was installed or not, but it could explain why the tech didn't bother to grease it.
I'm supposing that it's better to grease if not needed than skip it and find out I should have, but is there any issue? Is the grease just going to bleed out on the back side? Going to cause any pressure issues on the seals?
