Constant Alarm at WOT
2007 262BR with Mercruiser 350 Mag, Bravo 3, 125 hours. Had 2 beep every minute alarm. Took to dealer to have it scanned and it was found that the throttle position sensor and crankshaft position sensor were causing the fault. I replaced both sensors along with a new cap and rotor. Still have the 2 beep alarm which I figured I would until the codes were cleared. When I took it out after replacing those items I went WOT and it went to constant alarm and felt like power was down but it did not go into guardian mode. If I stay less than 4000 rpms it runs great. All fluids are good and gauges are reading normal. Its not overheating, impeller was changed last month. Any suggestions before I take it back to the dealer.
Best Answer
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
Could be low pressure on the raw water side. See: Encountering faults thread
