Rinker 320; Convert 2-step to 3-step going into the cabin?
MHamelinMHamelin Member Posts: 1
My wife has arthritis, and is having a hard time going up and down the 2-steps into the cabin.  Has anyone ever converted the 2-step configuration into a 3-step configuration?  Would love to hear any suggestions.
Thanks!
Mike
    edited June 2018
    That would have to be a custom job but could be done. Have to remove the stair post And reweld the brackets to be closer together. You would also need another cherry step. Diggin! Could make fhem
    Can you post a picture?
    I don’t think you could even cut down a FV342 step bracket to fit... it would still be a big space between the middle and top/bottom steps.
    I would pull the post and run it to a local welding shop. They'll either refit or recreate what you need from scratch. Get it in Stainless, or have it powder coated or chromed. Buy an extra step and you're all set.
    That's right dude
  • Dream_InnDream_Inn Member, Moderator Posts: 7,945 mod
    I believe the bottom step could probably stay where it is.  It is that first step when going into the cabin that needs raised and then another one added in the middle.  I agree with Dude, just have a shop do it.  Pretty simple job.
