Fiberglass delam
I'm in the middle of buying a 2002 Rinker 270 Fiesta Vee with a 15 inch diameter circle on the bow that is delam. The surveyor said it could take 500-750$ to fix. I live in South Bend IN and was wondering if Rinker knows of any places to fix this? I used to work in Goshen at Dutchmen RV for 6 years. The Rinker name I've heard good things. Does Rinker have a service shop?
Shane
Best Answer
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
Find Alswagg on here. He's near you and can help I'm sure.Post edited by Black_Diamond onPast owner of a 2003 342FV
Attaching photos was discussed in the link below. Good luck with your delam. Mike
(LINK TO PHOTO DISCUSSION)
Sorry, I misunderstood when you said bow I thought it was on the fwd section of the hull not the deck.
A soft spot in the deck is a bit different than a delam. It's usually caused by water leaks as RY said, causing the backing material (usually balsa) to rot away. There are a number of ways to repair a soft spot but as Al said it isn't cheap if you want it done right, but it can definitely be fixed if you pour some cash on it.
Good luck, Mike
