Filler cushions
I keep seeing filler cushions for the rear transom seat on a 2005 rinker fiesta vee 270. Was this an option for the boat to convert the back seat to a sun lounger. Besides having them custom made where can I get them? Would,make a great spot to sleep on. Thanks
    It is a great spot to hang out with a few pillows and a book. Our '04 270 came with the 2 lounge seat filler pieces. The fwd edge rests on the lip that's molded into the back wall of the port side cockpit seat. As I recall the aft edge of each piece has a pair of short rods that rest on the fwd edge of the rear seat molding in an indentation.
    A quick call to Rinker would be my best bet if I was looking to replace them. I'll see about getting a couple of pics and rough measurements if that'd help.
    Hope that description made sense. Mike
    Wow thanks that would be great
    On my 260 EC I have the same system. If you take off your seat cushions on your benches you will see a ledge moulded into the compartment walls. Two posts rest on each of these ledges to support the filler cushion.
    Thanks again! If you have any pictures that would be great. If I have to have them custom made pictures will help
    edited October 2013
    Here you go. Good luck. Mike (disclaimer: check your boat for consistent measurements as this was done early this morning after only one cup of coffee)
    Here you can see the indentation/ledges that the cushions rest on. Also notice above that the top edge has a delron strip of material about 3/4" sq along the edge. The half moon cut out fits around the side step on the port wall.
    Sorry for the delay getting back to you. Wow! You went above and beyond!! This will give me a great lead!
    Glad to help. Good luck. Mike
