Clean g gunk off isinglass
Britinusa
Member Posts: 306 ✭✭
Hi all, my issinglass of covered with a film of dirt, washing doesn't remove it, I have tried the clear view 2 part cleaner, 1/2 a bottle of cleaner used and a small section the size of my hand is slightly better but still can't see through it.
Any tricks to getting g the film of goop off, it feels tacky and rough, no idea what it is
Eisenglass is PVC and the UV from the sun eventually does that. Sadly no fix. Replacement time. You can upgrade to Strataglas, way better. Get the ‘thinner’ grade and it does roll to store, although not tight like Eisenglass. It will last many years longer though.
I tried ... once the dirt/mould chemically attacks the plastic ... it's done. I tried polishing it, everything ... yes, it was better ... but never clear. Bad areas were still foggy ... and you end up spending time and money trying to fix it ... for a few hundred, you can get a new section.
I will try the mild soap and soft brush first.
well, if you do get it clean, what do you use for a protectant? I have found aerospace 303 to be a very good protectant from UV and other environment hazards.
Need to use protectant ... the big issue also is to make sure water isn't sitting on it anywhere. Condensation in the morning could tend to pool in an area ... and then with the sunlight, mold, heat ... it damages it permanently.
But my boat is the only one like this, so it had to have happened when i pulled the boat and it was in the storage yard for 4 weeks with the canvas up before they shrink wrapped it.
