Top speed 2005 Fiesta Vee 270
We are looking at a 2005 Fiesta Fee. We love everything about it. Except the speed. We know it's a cruiser and do not expect high end speed. But, my husband is concerned it's super sluggish. He had the throttle all the way down it was running 6000 rpms (the speedometer is not working) and he felt like it was maybe going 20-20mph. What are y'all getting speed wise out of yours?
Thank you for your time!
I generally run at 3400 RPM which gives me a steady 24mph, any slower and it's hard to keep it on plane. That's with a fairly clean, un-painted bottom.
If you were showing 6000 RPM I'd say your tachometer is off. They are prone to read high, but if you wack it with the palm of your hand it'll usually fall back to the proper reading. If the speedo isn't working you should be able to use a GPS or even a GPS app on a phone to give you an idea of speed.
Andy
what motor ?
have the seller explain to you...what is wrong
*smooth freshwater, GPS averaged max speed between the upcurrent and downcurrent runs, empty water/waste tanks, 25 gallons of fuel, 2 adults and 3 kids under 5 years old, Bimini mounted. Stock propellers.
http://www.boattest.com/review/rinker/411_270-fiesta-vee
