Anchor does not drop
On my new to me 312, the anchor does not drop on its own. It requires that it be pushed, or better yet lefted slighty at the end near the windlass so it tips enough forward. -- once you give it some slack of the chain.
If I just try dropping it the chain piles up right there and gets jammed between the anchor and fiberglass. Not a good situation. the anchor just sits there.
On my 270 the anchor dropped on its own every time. The angles or something is different here that prevents it from falling.
I found this post where people mention that their anchors need nudging.
http://rinkerboats.vanillaforums.com/discussion/comment/99101#Comment_99101
Are there any fixes for allowing the anchor to drop on its own?
for now there is a piece of rope tied where the anchor attaches to the chain so it can be lifted slightly by someone as someone at the helm pushes the down switch.
I'd rather noone had to go on the bow to do this... and it will make it quite challenging when I am trying to drop anchor solo.
Thanks for suggestions.
Realize you're talking about a safety issue. It's easy to imagine situations where you can't send crew to the bow to fuss with the anchor. Example: narrow inlet, bad weather, the boat is rolling and pitching like crazy, and you lose power ... you have 20 seconds to drop a hook before the wind smashes you into a rock jetty.
BTW, this is why I don't use an anchor lanyard.
But haven't seen a case where an anchor won't fall when given slack. Wonder if it's not the original anchor? Curious what it's hanging on.
Regarding a larger anchor - my anchor is oversized for the boat as-is. No problems getting it to set in 6MPH tides, or on still lakes (except this past weekend, but the bottom is soft hydrilla and we all drug a few times before catching). Anything larger, with the 50+ feet of chain, and my windlass will need upgraded too.
I haven't seen a reason to think its not the original anchor.
(looks like I need to clean that bad boy out too)
Might see if you can spin the roller freely when the anchor is not on it. It could be bound, or worn out. The bend in the shank almost makes it look like it would hang up on that.
Gravity is just not doing it's job.
Not saying this is your issue but perhaps its contributing.
Below is a link to the unit i have.
https://www.go2marine.com/product/205377F/imtra-stainless-steel-swivel-anchor-connector.html?WT.srch=1&WT.mc_id=gb1&utm_source=googlebase&utm_medium=productfeed&utm_campaign=googleshopping&gclid=CjwKCAjwsJ3ZBRBJEiwAtuvtlORuVuVM6gwQv2lVOjYmy8QTXlyCOGhI71vnWqqdnh4YBMwxjsjjKRoCK4AQAvD_BwE
*hides behind something sturdy*
I used to be anal about cleaning it off. But not now. Weeds though......those go right away .
I'll check how they roll next time I visit the boat. I think the windlass would be better if it was higher by an inch or 2. The back end of the anchor is actually downwards as thats the way it follows the chain to the windlass. it pretty much lays toward the stern so not sure if easy spinning rollers would matter.
maybe its not the stock windlass... not sure about that. seems like it may be stock.
For some reason I think my 270 anchor butted up into the stainless flares on each side. In this image the roller is the limiter.
I still need to look into the twist as mentioned above, but I dont think that will make a difference as the weight of the anchor and chain seems to be more towards the stern in the full up position.
its fishfly time here, so sorry about the bugs in the pics.
If all else fails maybe you just need some anchor lube...
