FV310 with twin 5.0s -- Can't get on plane with a load
Hi everyone,
Just picked up a 2003 FV310 with twin 5.0s and BravoIIIs. We drove it back an hour and 40 minutes through lake michigan when we took ownership and she hauled very well with 3 passengers and no load. She even handled 2-4' waves like a champ and powered through them.
However..... The last two days have been extremely underwhelming. We've loaded 10 people on the boat (no gear really. just food and drink for the day) and I couldn't get the boat to plane out at all. Not once even with all the heavier males in the front of the cockpit. What should have been a 10 minute ride became a 25...
All I know about the prop situation is they are stainless.
Any thoughts or notes from current/previous owners? If this is something we can fix by changing props I'm all for it... If this is something we are going to have to live with due to the engine size... We may be have a whole other issue.
I will +++ on the Hill Marine 4x4’s.
As she builds up speed to where she is just shy of planing (usually close to 3K rpms) , I will push down the trim tabs to get the boat over the "hump" , so to speak. Speed rapidly builds after that without needing any more throttle.
Am I doing it wrong ?
2001 310 Fiesta Vee
T-5.0 FWC Mercs w/ B2
2001 310 Fiesta Vee
Going to replace the fuel filters this weekend as I just found out the P/O changed them last spring and she sat in cold storage over the winter. I also heard something about these having two different fuel filters? One fuel/water separator filter and then another inline? Anyone care to verify or supply part numbers or do I need to get down there and open her up first? (again its a late model 2003 FV310)
A “yacht certified” boat does not have a stated person capacity. USCG will tell you 1 person per 3’ of boat as a general guideline. Even on my 342 10 is a lot of people/weight plus all the goodies.
I will say the 4 blades were well worth the money for me.
2001 310 Fiesta Vee
Also put a can of seafoam in each gas tank as a prevent maintenance. We only get 89 octane here at most of the harbors which stinks... I use 93 in all my cars and am a performance enthusiast with automobiles.
Once I got all done, I let the engine compartment air out for about 20 minutes of the fuel smell, with blowers on, and did some cleaning down there.
Fired her up, no issues or leaks. Will be testing her out tomorrow and Sunday as its looking to be about 90* here in Chicago both days. Engines purr nicely... So after this, I may just look into the 4x4 HillMarines to help with performance. time will tell.
