kohler 5ekd smokes a lot
determined
Member Posts: 16 ✭✭
Hello,
I have a Kohler 5EKD in my 2012 360 EC. Gen has 60 hrs on it. I just replaced the impeller and had several days fun getting the air out of the system after having disconnected a hose in order to get at the impeller housing. This caused no end of overhead shutdown faults until I purged all the air out. The generator runs fine now but the temp reads 198F. Does anyone know the normal operating range of these units. There is no mention in the manual.
My second question, is this - is it normal for these units to smoke a lot. Its white smoke.
I'm the second owner of this boat and this is my first full season with it. I owned a previous rinker with a 5 EC genny and don't remember this much smoke. The oil level is normal and there seems to be adequate cooling water exhaust now that I replaced the impeller. I'm thinking maybe the overheats and shut downs (at least 5 of them) caused the impeller to die or the plugs are bad. Any one had anything like this before?
Thank you everyone, in advance, for your help.
Jean-Marie
White ‘smoke’ would imply steam usually. The raw water impellor would not be affected by the engine over heat. Plugs...the 5e just eats them. Even if they look good...replace.
I've always had good luck with NGK.
Let us know how it goes. If it does not fix the problem, there are certainly some other things to look at it and try. The plugs are just generally something that needs changed often and definitely the easiest, best place to start.
When Kohler does the recall service, ask them to backflush the heat exchanger in case you have any pieces of impeller lodged in the system.
