Replace static windows on 342
Stodge
Member Posts: 2,738 ✭✭✭✭
Has anybody replaced the non-opening windows on their 342? There are 3 of them, I think all have cracks and I'd like to replace them. Just wonder what the process is (remove from inside versus outside) and where replacements were found.
https://greatlakesskipper.com/custom-18-x-8-inch-fixed-boat-port-windows-pair
Hmmmm, wonder if our resident "maker of cool wood and plastic stuff" a.k.a. @diggin2day1 could make some replacement tinted plexiglass (or whatever they use) if provided a model.
Mine are cracked and discolored. And the seals are nearly gone. So what I want to do is replace the windows with new ones, which are either not available or crazy expensive.
Assuming you can work the material used to replace them, I think you could add a new product to your line. Once it gets colder I plan to remove one of the windows to use as a model for duplication. I figured you'd be as good as anybody to do the duplicating.
I'll follow up with you a a couple months when the shrink wrap goes up and work out the details. For now I was just curious if you could make stuff out of tinted plexiglass.
BTW, what's the commission for new products? There have to be a few other folks who'd like to replace their windows too.
