Horizon 600 windlass problem
04FV270riverrat04FV270riverrat Member Posts: 268 ✭✭✭
so my windlass on my 270 will let the anchor down, but won’t pull it up. It pulls really slow for about 10-20 seconds, then it blows the 50amp breaker back by the battery switch. I tested amp while pulling and it draws about 34 amps before the breaker pops. All connections are tight (switch/breaker isolator/breaker at battery switch panel). Once it pops the breaker a couple times, it won’t move in the up function at all. I’m hoping the motor inside the windlass can be rebuilt or replaced. Anyone ever have this issue?
