Help diagnose a sound?
I've been looking for the cause of this for a few years. It's very intermittent, and only happens on start up. After the engine has been running for 10-15 seconds it stops, and it only does it at idle, but it'll make the noise regardless of in gear, or out of gear. When we were out yesterday it only did it once, but sometimes it'll do numerous times. It's random and intermittent. The noise is coming from the rear of the engine, ie....not a belt or idler pulley. It's been happening for a few years, and since I've first heard the noise, both the entire transom assembly, and outdrive have been replaced, and it's still here. So basically, everything behind the motor is new, and it was doing it before all that was replaced. Any ideas?
https://m.youtube.com/watch?v=EfDamwbIQgc
https://www.harborfreight.com/mechanics-stethoscope-69913.html
I have ave one of those but I’ve never been quick enough to catch it since it doesn’t always do it, and it doesn’t do it for very long. That video is about the longest I’ve ever heard it do it. Lol
When my race car starts having an issue we can’t figure out, I always say “let’s go make a nitrous hit and we will figure it out.” I tell my wife we will figure out what it is when it fails, but it keeps going.
Or or I can just not use the blower anymore
If your sure it's from the back end.
Pinion return spring or sticky pinion on starter maybe?
Have you ever noticed you feel like you are not getting as much speed as you used too, or if you get on the throttles hard to you hear that noise?
I did have to replace a power steering hose last year.
