Outdrive trim not working
Hey folks I have a 2004 250 fiesta vee 5.0. Hadn't been to the boat in a while and had left my engine trimmed up. When tried to put down the trim motor would not work. The relays click when both up and down are pressed but the pump does not work. Was fine when I left it. Removed the pump motor from the unit and it looks fine, checked all connections. Any ideas?
Also on other videos I see three wires going into the motor. 1 gnd and 1 for each direction. Mine only has two, so how does it reverse polarity and spin the other way?
