Actual portable AC...
Perfect for a cuddy or boat that didn't come with AC in it.. little pricey, but at least not as big as that huge *** deck hatch version..
https://www.youtube.com/watch?v=PmZLsadGlmg
For the states east of the Mississippi River the best a coil that size could do is slightly lower humidity (dehumidification is a function of surface area, not temperature). If you can put it in a closed system, you could eventually strip all the moisture from the air, but where's it going to go? Without a tank or external drain it'll just pool on the floor, to be re-evaporated (remember that cool, dry air you just made? That's the most effective environment for evaporation!)
West of the Mississippi, in dry areas, this might function, but at X-times the cost of an evaporative cooler, where X is likely much greater than 5. An evaporative cooler is a fan and a water source, with a sponge: you wet the sponge, blow air over it, the air gives up it's heat to change the phase of the liquid water to water vapor, and the net result is humid air at a lower temperature. It's much cheaper, less power draw, and only needs a source of water (even warm water will work).
The device would have to defy laws of physics to work here in Charleston, SC. This thing is too small: it will just blow slightly dryer warm air over us.
